Class AcadTextStyle
Member of BricscadDb
The TextStyle object contains the settings that determine the appearance of text. To access the TextStyle object, use the following methods and properties.
| Methods | Properties |
| Delete | Application |
| GetExtensionDictionary | BigFontFile |
| GetFont | Document |
| GetXData | FontFile |
| SetFont | Handle |
| SetXData | HasExtensionDictionary |
| Height | |
| LastHeight | |
| Name | |
| ObjectID | |
| ObjectName | |
| ObliqueAngle | |
| OwnerID | |
| TextGenerationFlag | |
| Width |
