Direct Distance Entry (DDE) means that you can type the length of lines, polyline segments, circle radii and diameters, movement vectors in commands such as Move, Copy and Stretch, etc. in the command bar.
When combined with either Orthogonal Mode or Polar Tracking, Direct Distance Entry is a particularly efficient method to draw lines of a specified length and direction, and to move or copy objects over a specified distance.
To help you keep track of the position of the cursor it is recommended to set the readout of the coordinate field in the Status Bar to Relative.
To define the Coordinates setting
Do one of the following:
Right click the then choose Relative in the context menu.
Click the Coordinates field in the status bar to cycle the Coordinate setting. The sequence is Off, Relative, Absolute.
Type coords in
the command bar, then press Enter.
Type 2 and press Enter.
Open the Settings
dialog and expand the Display/Viewing settings sub-category under
Drafting in the Drawing settings class.
Set the Coordinates setting to
Coordinates in polar form for point,
distance and angle selection.
