Commands: DIST, AREA, MASSPROP, ID and LIST
The Dist command reports the distance and angle between two points.
The Area command finds the area and perimeter (or length) of 2D entities.
The Massprop command reports the area, perimeter, and other mathematical properties of 3D solids and 2D regions (short for "mass properties").
The ID command reports the x,y,z coordinates of picked points.
The List command lists the properties of selected entities.
To measure a distance between two points:
Do one of the following:
Click the Distance tool button (
) on the Measure toolbar.
Type dist in the command bar and press Enter.
The command bar reads: Starting point for distance:
Identify the first point.
The command bar reads: End point:
Identify the second point.
The following information displays in the command bar (see image below):
Distance, Angle in XY Plane (alpha), Angle from XY
Plane (beta),
Delta X, Delta Y, Delta Z.
The values are calculated with respect to the current coordinate system.
To measure the length of single linear entity, click the entity then read the Length field in the Properties Bar.
To add the lengths of a series of linear entities:
Click the Area tool button (
Type area in the command bar and press Enter.
The command bar reads: Entity/Add/Subtract/<First point>:
A prompt menu displays:
Choose Add areas together in the prompt menu.
Type A in the command bar and press Enter.
The command bar reads: Adding: Entity/Subtract/<First point>:
Choose Add entities to area in the prompt menu.
Type E in the command bar and press Enter.
The command bar reads: Adding area<Select entities>:
Click the first entity.
The area and length of the first entity display in the command
bar.
Click the second entity.
The area and length of the second entity and the total area and
total length display in the command bar.
Optionally press the F2 function key
to display the Prompt History window;
press F2 again to close the
Prompt History window.
Repeat step 5 to add more entities
or
press the Esc key to stop.
To measure the area and length of single closed entity, click the entity then read the Area and Length fields in the Properties Bar.
To measure areas and perimeters by specifying points in a drawing:
Click the first corner point of the area.
A dashed line displays dynamically from the first corner point.
The command bar reads: Adding: <Next point>:
Click the second corner point of the area.
A dashed polygon displays dynamically, indicating the currently
defined area.
Click the third corner point of the area.
Repeat step 5 to add more corner points
or
Right click to stop adding corner points.
The Total length and Total area display in the command bar.
Repeat steps 3 through 6 to add another area.
Press the Esc key to stop.
