Works with Bricscad (Windows) Pro
Reports the area, perimeter, and other mathematical properties of 3D solids and 2D regions (short for "mass properties").
command bar: massprop
menu bar: Tools | Inquiry | Mass Properties
toolbar: Inquiry | ![]()
: massprop
Select entities: (Choose one or more ACIS objects.)
Entities in set: 1
Displays report in the command bar; press F2 to view report in the prompt history window:
Write analysis to a file? (Type Y or N.)
When you enter Y, displays dialog box:
Name the file, and then click Save.
The report is stored in an MPR file, which can be opened in any text editor.
MPR is short for "mass properties report."
Specifies the entities on which to report properties. Choose the 3D solid models and 2D region entities; all other entities are ignored by Bricscad. |
Writes the report to a text file. Type Y or N:
Enter a file name, and then click Save. The report is stored in an MPR file, which can be opened in any text editor.
Region - creates 2D regions from 2D entities.
Sphere - creates 3D balls as solid models.
