In Bricscad you can navigate through your drawing using the mouse.
Mouse / Key |
Action |
Result |
Mouse Wheel |
scroll |
Zoom in / out (*) |
Middle Button (**) |
press and hold while moving the mouse |
Real-time pan |
double click |
Zoom extents |
Ctrl + Shift + Left Button |
Zoom in / out |
Ctrl + Shift + Right Button |
Real-time pan |
Ctrl + Left Button |
Real-time sphere |
Ctrl + Right Button |
Rotate about the screen Z-axis |
(*) The incremental change in zoom with each mouse-wheel action is controlled through the Zoom Factor variable (ZOOMFACTOR).
(**) On condition the Middle Button Pan (MBUTTONPAN) variable is set ON.
Setting the Zoom Factor variable
Type zoomfactor in
the command bar, then press Enter.
The command bar reads: New current value for ZOOMFACTOR (3 to 100)
<current value>:
Type a value between 3 and 100 in the command bar, then press Enter.
or
In the Settings
dialog, open the Drawing category,
then expand the Display/Viewing
sub-category.
In the Viewing group, select the
ZOOMFACTOR variable.
Type a value between 3 and 100 in the zoomfactor field.
NOTE |
Increase the zoom factor to speed up scroll wheel zooming in large drawings. |
Setting the Middle Button Pan variable
Type in mbuttonpan
The command bar reads: New current value for MBUTTONPAN (Off or On)
<current value>:
Type On or Off in the command bar.
or
In the Settings dialog, open the Program Options category, then expand the User Preferences sub-category and select the MBUTTONPAN variable.
Choose either Support panning or Support action defined in menu file.
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV are fully owned subsidiaries of Menhirs NV. Copyright © 2001- Menhirs NV - All rights reserved. |
