A dimension style consists of six settings groups
Do one of the following:
Click the Dimension
Variable Status tool button () on the Dimensions toolbar.
Choose Dimension Variable Status in the Dimensions menu.
A list of all dimension variables displays in the command bar.
Press the F2 function key to open the Bricscad Prompt History window.
Press Enter to continue the listing.
Press the F2 function key to close the Bricscad Prompt History window.
Name |
Settings |
Arrow 1 |
DIMBLK1 |
Defines the arrow type for the arrow of the first dimension line (Dim line 1) |
Arrow 2 |
DIMBLK2 |
Defines the arrow type for the arrow of the second dimension
line (Dim line 2) |
Arrow size |
DIMASZ |
Sets the size of the arrows in drawing units. |
Leader arrow |
DIMLDRBLK |
Defines the arrow type created by the Leader tool. |
Dim line color |
DIMCLRD |
Sets the color of the dimension line. |
Dim line LW |
DIMLWD |
Sets the line weight of the dimension line. |
Dim line linetype |
DIMLTYPE |
Sets the line linetype of the dimension line. |
Dim line ext |
DIMDLE |
Defines the extension of the dimension line beyond the extension lines, when arrowheads are set to oblique or architectural ticks. |
Dim baseline spacing |
DIMDLI |
Sets the spacing of the dimension line for stacked baseline dimensions. |
Dim line 1 |
DIMSD1 |
Controls the display of the first half of the dimension line, from the first extension line to the origin point of the dimension text. |
Dim line 2 |
DIMSD2 |
Controls the display of the second half of the dimension line, from the origin of the dimension text to the second extension line. |
Ext line color |
DIMCLRE |
Sets the color of the extension lines |
Ext line LW |
DIMLWE |
Sets the line weight of the extension lines |
Ext line ext |
DIMEXE |
Defines the extension of the extension lines beyond the dimension line. |
Ext line offset |
DIMEXO |
Defines the offset of the extension lines from the dimension origin points |
Ext line 1 |
DIMSE1 |
Controls the display of the first extension line. |
Ext line 2 |
DIMSE2 |
Controls the display of the second extension line. |
Ext line type 1 |
DIMLTEX1 |
Sets the linetype for the first extension line. |
Ext line type 2 |
DIMLTEX2 |
Sets the linetype for the second extension line. |
Ext line fixed |
DIMLFXLON |
Determines whether fixed length extension lines are used. |
Ext line fixed length |
DIMFXL |
Specifies the length of the extension lines, measured from the dimension line (= DIMEXE excl.), if DIMFXLON is on. |
Center mark |
DIMCEN |
Defines the type of entity that will be created by the
Dimcenter tool. |
Center mark size |
DIMCEN |
DIMCEN=0: no center mark, nor center lines are drawn DIMCEN>0: a center mark is drawn, the value of DIMCEN defines the length of the center mark lines. DIMCEN<0: a center mark and center lines are drawn; the abosolute value of DIMCEN defines the extension of the center lines outside the arc or circle and the gap between the center mark and the center lines. |
Arc length symbol |
DIMARCSYM |
Controls how the arc symbol displays in an arc length dimension |
Jog angle |
DIMJOGANG |
Specifies the angle of the oblique dimension line segment in jogged radius dimensions |
NOTE |
Dimension lines and extension lines are created in the current line type. |
Name |
Settings |
Text style |
DIMTXSTY |
Defines the text style of the dimension text. |
Text color |
DIMCLRT |
Defines the color of the dimension text. |
Text fill |
DIMTFILL |
Sets the dimension text background.
Left: Background = drawing window background color (BKGCOLOR). Right: Color = color defined by DIMTFILLCLR. |
Text fill color |
DIMTFILLCLR |
Defines the text background color |
Text height |
DIMTXT |
Sets the height of the dimension text in drawing units. |
Draw frame around text |
DIMGAP |
Toggles the text frame on/off. A frame is drawn if DIMGAP is negative. |
Text offset |
DIMGAP |
Sets the offset distance around the dimension text and the
distance between annotation and hook line created using the
Leader
command. |
Text pos vert |
DIMTAD |
Defines the vertical text position with respect to the dimension line. |
Text pos hort |
DIMJUST |
Defines the horizontal position of the text with respect to the extension lines. |
Text offset vertical |
DIMTVP |
Sets the vertical position of dimension text above or below the
dimension line when DIMTAD=0. |
Text inside align |
DIMTIH |
Defines whether text that is placed inside the extension lines is aligned with the dimension line or placed horizontally. |
Text outside align |
DIMTOH |
Defines whether text that is placed outside the extension lines is aligned with the dimension line or placed horizontally. |
The vertical position of the dimension text is controlled through three settings variables: DIMGAP, DIMTAD and DIMTVP.
The scheme below illustrates the compound effect of these three settings variables:
Settings |
Result |
DIMGAP=0 DIMTAD=0 DIMTVP=0 |
DIMGAP=0.2 DIMTAD=0 DIMTVP=0 |
DIMGAP=-0.1 DIMTAD=0 DIMTVP=0 |
DIMGAP=0 DIMTAD=1 DIMTVP=0 |
DIMGAP=0.2 DIMTAD=1 DIMTVP=0 |
DIMGAP=-0.1 DIMTAD=1 DIMTVP=0 |
DIMGAP=0 DIMTAD=0 DIMTVP=1 |
DIMGAP=-0.1 DIMTAD=0 DIMTVP=1 |
Name |
Settings |
Arrow and text fit |
DIMATFIT |
Determines how text and arrowheads are placed if there is not enough room to fit both, text and arrowheads between the extension lines. |
Text inside |
DIMTIX |
Forces text to be placed inside, arrowheads outside. |
Dimline inside |
DIMSOXD |
Suppresses the dimension lines to be drawn outside the extension lines. |
Text movement |
DIMTMOVE |
Specifies whether the dimension line moves with the text or that text can be moved independently. This setting also specifies if a leader needs to be drawn if the text is moved away from the dimension line. |
Dim scale overall |
DIMSCALE |
Defines a scale factor for all entities in the dimension block. |
Place text manually |
DIMUPT |
Allows to place text manually when creating the dimension block. |
Dimline forced |
DIMTOFL |
Forces the dimension line to be drawn, even when the text is placed outside. |
Name |
Settings |
Dim units |
DIMLUNIT |
Defines the unit type for the primary units. |
Dim precision |
DIMDEC |
Sets the precision for the primary units. |
Fractional type |
DIMFRAC |
Determines the fractional type if Dim Units is Fractional. |
Decimal separator |
DIMDSEP |
Sets the decimal separator character |
Dim round |
DIMRND |
Specifies the roundoff rule for linear dimensions. E.g. if set to 0.1, all dimensions will be rounded to the nearest 0.1 unit. If set to 0, dimensions are not rounded. |
Dim prefix |
DIMPOST |
Text string placed in front of the dimension text. |
Dim suffix |
DIMPOST |
Text string placed after the dimension text. |
Dim scale linear |
DIMFLAC |
Scale factor for the primary units. E.g. if your drawing units are mm and you want your dimensions to be expressed in cm, set the scale factor to 0.1. |
Suppress leading zeros |
DIMZIN |
Suppresses the zero that is placed before the decimal separator. If on, a distance of 0.0124 will display as .0124. |
Suppress trailing zeros |
DIMZIN |
Suppresses trailing zeros in decimal values. If on, a distance of 125,00 displays as 125 and 82.50 displays as 82.5 if Dim Precision is 2. |
Suppress zero feet |
DIMZIN |
Suppresses zero feet values in imperial units. |
Suppress zero inches |
DIMZIN |
Suppresses zero inches values in imperial units. |
Dim angle units |
DIMAUNIT |
Sets the unit for angular dimensions |
Dim angle precision |
DIMADEC |
Sets the precision for angular dimensions |
Suppress angle |
DIMAZIN |
Suppresses leading zeros in angular dimensions |
Suppress angle |
DIMAZIN |
Suppresses trailing zeros in angular dimensions |
Name |
Settings |
Alt enabled |
DIMALT |
Adds alternate units to the dimension text. |
Alt units |
DIMALTU |
Sets the unit type for the alternate units. |
Alt precision |
DIMALTD |
Sets the precision for the alternate units. |
Alt scale factor |
DIMALTF |
Sets the scale factor for the alternate units. E.g. if the primary units are imperial and the alternate units are decimal (mm), then the alternate units scale factor must be set to 25.4. |
Alt round |
DIMALTRND |
Roundoff rule for the alternate units in linear dimensions. E.g. if set to 0.1, alternate units will be rounded to the nearest 0.1 unit. If set to 0, alternate units are not rounded. |
Alt prefix |
DIMAPOST |
Text string placed in front of the alternate dimension text. |
Alt suffix |
DIMAPOST |
Text string placed after the alternate dimension text. |
Alt suppress leading zeros |
DIMALTZ |
Suppresses the zero that is placed before the decimal separator in alternate units. If on, a distance of 0.0124 will display as .0124. |
Alt suppress trailing zeros |
DIMALTZ |
Suppresses trailing zeros in decimal values in alternate units. If on, a distance of 125,00 displays as 125 and 82.50 displays as 82.5 if Dim Precision is 2. |
Alt suppress zero feet |
DIMALTZ |
Alt suppress zero inches |
DIMALTZ |
Suppresses zero inch values in imperial units. |
Name |
Settings |
Tolerance display |
DIMTOL |
Adds tolerances to dimension text. If DIMTOL is On, DIMLIM is switched Off. |
Limits display |
DIMLIM |
Sets the default text to dimension limits. If DIMLIM is On, DIMTOL is switched Off. |
Tolerance precision |
DIMTDEC |
Sets the precision for dimension tolerances. |
Tolerance limit lower |
DIMTM |
Sets the lower limit for dimension tolerances. |
Tolerance limit upper |
DIMTP |
Sets the upper limit for dimension tolerances. |
Tolerance text height |
DIMTFAC |
Sets the text height for the tolerance settings with respect to the dimension text height. E.g. if set to 0.5, the tolerance text height is half the height of the dimension text. |
Tolerance pos vert |
DIMTOLJ |
Determines the vertical position for dimension tolerances with respect to the dimension text. |
Tolerance suppress leading zeros |
DIMTZIN |
Suppresses leading zeros. |
Tolerance suppress trailing zeros |
DIMTZIN |
Suppresses trailing zeros. |
DIMTZIN |
DIMTZIN |
Alt tolerance precision |
DIMALTTD |
Sets the precision for dimension tolerances in alternate units. |
Alt tolerance suppress leading zeros |
DIMALTTZ |
Alt tolerance suppress trailing zeros |
DIMALTTZ |
Alt tolerance suppress zero feet |
DIMALTTZ |
Alt tolerance suppress zero inches |
DIMALTTZ |
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV are fully owned subsidiaries of Menhirs NV. Copyright © 2001- Menhirs NV - All rights reserved. |
