Bricscad works on:
Microsoft Windows 7, Vista, XP, 2000 on both
32 and 64 bits.
You have the choice between 3 different levels : Platinum, Pro or
Classic.
Linux: Ubuntu, Fedora, OpenSUSE - 32bit,
64bit - gnome, kde
Ubuntu 9.04 or later, Fedora 11 or later, OpenSUSE 11.0 or
later
You have the choice between 2 different levels : Pro or Classic.
WINDOWS |
LINUX |
Platinum |
Pro |
Classic |
Pro |
Classic |
| eDrop |
| ActiveX, Including in-place-editing |
Component Object Model (COM) |
Visual Basic for Applications (VBA) |
BRX |
ACIS Editing |
.NET |
Rendering |
X-Solids |
X-Hardware |
NOTE |
If you have bought a Platinum or Pro license key, do the following to install VBA after running Bricscad in trial mode or when upgrading Bricscad Classic:
Launch the Bricscad installer (e.g. Bricscad-V11.2.2-1-en_US.exe).
Choose the Modify option, then click the Next button.
Accept the terms of the license agreement, then click the Next button.
On the License Information dialog click the Modify... button.
Enter your Platinum or Pro license key in the Key field on the Enter License Key for Bricscad dialog.
Click the OK button to confirm the license key.
On the next dialog, check the VBA checkbox in the features list, then click the Next button.
Follow the next instructions of the installer software.
Related Topics:
