Works with Bricscad (Windows) Classic, Pro and Platinum, Bricscad (Linux) Classic and Pro
Sets default values for creating entities (short for "dynamic dialog entity modes").
command bar: ddemodes
alias: settings
: ddemodes
Displays Settings dialog box at the Entities section:
Change settings, and then click X.
Specifies the default color of new entities; default is ByLayer, which means that entity colors are governed by layer properties. |
Specifies the default scale factor for linetypes; default is 1.0000. |
Specifies the default linetype for new entities; default is ByLayer, which means that entity linetypes are governed by layer properties. |
Specifies the default linetype for new entities; default is ByLayer, which means that entity lineweights are governed by layer properties. |
Specifies the default layer for new entities; default is layer 0. |
Specifies the default table style for new tables. |
Specifies the global linetype scale factor; this factor affects entity linetype scale factors. |
Color and -Color - set the working color.
LtScale - sets the current linetype scale.
Linetype and -Linetype - loads linetype definitions and set the current linetype.
LWeight - sets the current linetype.
Layer and -Layer - create layers and set their properties.
Properties - reports and changes properties through a palette.
