Works with Bricscad (Windows) Classic, Pro and Platinum, Bricscad (Linux) Classic and Pro
eTransmit creates a package of a drawing file and all its dependencies, such as: external references, images, font files, plot configuration files, plot style tables and font map files.
eBridgeToVondle starts where eTransmit ends. With eBridge, Bricscad connects to Vondle™. eBridge and Vondle allow to manage, view, share and log all file versions of a CAD project. eBridgeToVondle does not work with the Linux versions of Bricscad.
To be able to use eBridge to Vondle you need:
Access to a Vondle project.
The latest version of Vondle Explorer
command bar: etransmit
alias: none
menu bar:
File| eTransmit/eBridge
Settings | Dependencies
: etransmit
Click
etransmit (
) in the Details toolbar to start the
eTransmit procedure.
A dialog box displays:
Select the files to be included in the eTransmit package, then click the Transmit button.
Adjust the settings, then click the Transmit button.
Displays a report:
eTransmit Command Options
Destination folder: |
Specifies the output folder for the eTransmit package. If the destination folder does not exist, you are prompted to create the folder. |
Save format: |
Specifies the format of the drawing files in the eTransmit package.
If file exists: |
Specifies what to do if a file already exists in the output folder.
Output: |
Specifes whether to create a ZIP file or copy the files to the output folder.
Send email: |
If checked, sends an email with the zipped eTransmit package in attachment. This option is available if the eTransmit output is a ZIP file only. |
ZIP file: |
Specifies what to do if a ZIP file of the same name already exists in the output folder.
Update image paths |
If checked, the saved paths for image files are updated, according to the new location. |
Update xrefs paths |
If checked, the saved paths for xrefs are updated, according to the new location. |
All files in one folder |
All files in the eTransmit package are copied to the destination folder. |
Organized folder structure |
A hierarchical folder tree is created in the destination folder |
Keep files and folders as is |
Keeps the folder structure of all files in the eTransmit package. This procedure allows to easily install the package on another computer using the folder structure of the source system. |
Source root folder: |
Specifies the source root folder for relative paths of drawing-dependent files, such as xrefs or image files. |
Click eBridge to
Vondle (
eBridge procedure.
Select the files to be included in the eBridge to Vondle procedure, then click the Upload button.
Type your User name and Password, then click the Log In button.
Click the Select project/folder button.
Select a folder, then click the OK button.
Click the OK button on the Add document(s) dialog box.
Displays a report:
Click the OK button to close the report dialog.
eBridge Command Options
Select a document, then double click the description field to add a description.
Status |
Select a document, then click the down-arrow button in the status field to select a different status.
