Works with Bricscad (Windows) Classic, Pro and Platinum, Bricscad (Linux) Classic and Pro
Sets a password to protect your drawing.
command bar: securityoptions
alias: none
menu bar: File | Security Options
: securityoptions
Key-in the password, then click the OK button.
A dialog box displays:
Confirm the password, then click the OK button.
Specifies the encryption level for drawing properties. Choose an encryption provider supplied the operating system.
Sets the length of the encryption key. The longer the key, the higher the level of protection is.
Dwgprops: opens the Drawing Properties dialog box
QSave - saves the drawing without displaying the Save dialog box.
Save - saves the current drawing through a dialog box.
SaveAll - saves all open drawings.
Open: opens a drawing
