Works with Bricscad (Windows) Classic, Pro and Platinum, Bricscad (Linux) Classic and Pro
Opens drawing (DWG), template (DWT), and interchange (DXF) files.
command bar: open
shortcut: Ctrl+O
aliases: op, im, import
menu bar: File | Open
toolbar: Standard |
: open
Choose a file, and then click Open.
Selects the drive and folder. |
Specifies the name of the file. |
Selects the type of file:
Opens the file. |
Closes the dialog box without opening a file. |
Opens the drawing in read-only mode. The drawing cannot be saved to the same file name. |
Displays the preview image of the drawing. |
Close - closes the current drawing.
CloseAll - closes all open drawings.
Quit - exits Bricscad after closing open drawings.
New - starts new drawings.
SecurityOptions - sets a password to protect a drawing
