DocumentPreferences object
Class AcadDatabasePreferences
Member of BricscadDb
The DocumentPreferences object contains certain settings for the active document (drawing).   The settings of a document that are saved in a drawing (not the registry).The DocumentPreferences object has no applicable methods, but can be accessed with the following properties:
Properties
Application
ContourLinesPerSurface
DisplaySilhouette
MaxActiveViewports
Parent
RenderSmoothness
SegmentPerPolyline
SolidFill
TextFrameDisplay
XRefLayerVisibility
