Sets or returns the number of contour lines per surface for entities in a given document. The value of this property is stored in the ISOLINES system variable.
Syntax
where:
integerVariable is a variable for storing the number of contour lines.
object is the DocumentPreferences object.
Examples ...
ContourLinesPerSurface property example
© Menhirs NV. All rights reserved. |
