Preset property
Sets or returns whether the Attribute or AttributeDef is a preset attribute (True) or not (False). A preset attribute sets the attribute to its default, or preset, value when the user inserts the block. An attribute may exist as only one of four optional modes: constant, preset, invisible, or verify.
Syntax
BooleanVariable = object.Preset
object.Preset = <Boolean>
Where:
     BooleanVariable specifies whether the attribute mode is preset or not.
     object is the Attribute object.
Examples...
Attribute properties example
