Attribute object
Class AcadAttribute
Member of BricscadDb
An Attribute (known as  Attribute Definition in Bricscad) defines the prompt, tag string, default value, and display characteristics of an attribute. When you insert a block into a drawing you get a BlockRef object. If the BlockRef "has attributes," you can iterate through the Attribute objects in the Attributes collection using the HasAttributes property. Each Attribute is an individual instantiation of the Attribute Definition object in the Block. It is this Attribute object that contains the value of the attribute.
To access the Attribute object, use the following methods and properties:
Methods Properties
ArrayPolar Alignment
ArrayRectangular Application
Copy Backward
Delete Constant
GetBoundingBox Document
GetExtensionDictionary FieldLength
GetXData Handle
Highlight HasExtensionDictionary
Hyperlinks Height
IntersectWith Hyperlinks
Mirror InsertionPoint
Mirror3D Invisible
Move Layer
Rotate Linetype
Rotate3D LinetypeScale
ScaleEntity Lineweight
SetXData LockPosition *
TransformBy Material *
Update Mode
  Normal
  ObjectID
  ObjectName
  ObliqueAngle
  OwnerID
  PlotStyleName
  Rotation
  ScaleFactor
  StyleName
  TagString
  TextAlignmentPoint
  TextGenerationFlag
  TextString
  Thickness
  TrueColor
