Commands: DIMDIAMETER and DIMRADIUS
Diametrical and radial dimensions annotate the radii and diameters of circles and circular arcs.
The DIMCENTER command creates center marks in the center point of circles and circular arcs.
To create a diametrical dimension
Do one of the following
Click the Diameter tool button () on Circles toolbar or the Circles flyout of the Dimensions toolbar.
Choose Diameter in the Dimensions menu.
Type dimdiameter in the command bar, then press Enter.
The command bar reads: Select arc or circle
Select the arc or circle you want to annotate.
The diametrical dimension displays dynamically.
Position the dimension line.
Click the Radius tool button () on Circles toolbar or the Circles flyout of the Dimensions toolbar.
Choose Radius in the Dimensions menu.
Type dimradius in the command bar, then press Enter.
The radial dimension displays dynamically.
Creating center marks or center lines
Click the Center tool button () on Circles toolbar or the Circles flyout of the Dimensions toolbar.
Choose Center in the Dimensions menu.
Type dimcenter in the command bar, then press Enter.
The command bar reads: Select arc or circle to dimension:
Select the arc or circle.
The center marks are created.
NOTE |
© Menhirs NV. All rights reserved. |
