Works with Classic, Pro and Platinum
Dimensions the diameter of circles and arcs, and places the center mark.
command bar: dimdiameter
aliases: ddi, dimdia
menu bar: Dimension | Diameter
toolbar: Dimensions | Circles
: dimdiameter
Select arc or circle to dimension: (Choose an arc, polyline arc, or circle.)
Dimension text = \A1;%%c2.5806
Angle/Text/<Location of dimension line>: (Position the dimension, or enter an option.)
A circle with diameter dimension placed outside
An arc with diameter dimension placed inside
Chooses the arc, polyline arc, or circle to dimension. |
Locates the dimension leader line and text; drag the dimension around the entity, and inside or outside the entity. |
Changes the angle of the text. |
Changes the default text generated by Bricscad. |
Grips Editing
Diameter dimensions can be edited directly through grips:
Select the diameter dimension. Notice the grips.
Drag either grip on the circle to rotate the dimension around the circle.
Drag the grip on the leader to relocate it and the associated text.
