Chamfering Entities
Command: CHAMFER
The Chamfer command connects two non-parallel entities by extending or trimming them and then joining them with a line to create a beveled edge.
In Bricscad you can choose between two chamfer methods:
The following entities can be chamfered: lines, polylines, rays and infinite lines. When chamfering a polyline, you can create a chamfer between two polyline segments or you can chamfer the entire polyline.
 Chamfering using the distance-distance method
  1. Do one of the following:
  2. Click the Chamfer tool button () on the Chamfer/Fillet flyout of the Modify toolbar.
  3. Choose Chamfer in the Modify menu.
  4. Type chamfer or CHA in the command bar, then press Enter.
The command bar reads: Chamfer (<current chamfer settings>): Settings/Polyline/Angle/Distance/mEthod/Trim/Undo/Multiple/<Select first entity>:
A prompt menu displays:
  1. (option) Choose Chamfer Settings ... in the prompt menu or type S and press Enter.
    In the Settings dialog window:
  2. Specify the Chamfer first distance.
  3. Set the Chamfer second distance.
  4. Set the Chamfer mode to Distance-Distance.
Close the Settings dialog window.
  1. Select the first entity or polyline segment.
    The command window reads: Select second entity.
  2. Select the second entity or polyline segment.
    The chamfer is created.
 Chamfering using the length-angle method
The command bar reads: Chamfer (<current chamfer settings>): Settings/Polyline/<Select first entity>:
A prompt menu displays.
  1. Choose Chamfer Settings ... in the prompt menu or type S and press Enter.
  2. In the Settings dialog window:
  3. Specify the Chamfer length.
  4. Set the Chamfer angle.
  5. Set the Chamfer mode to Length-Angle.
  1. Close the Settings dialog window.
  2. Select the first entity or polyline segment.
  3. Select the second entity or polyline segment.
Chamfering all vertices of a polyline
  1. (option) Adjust the Chamfer Settings.
  2. Choose Polyline in the prompt menu or type P and press Enter.
    The command bar reads: Select 2D polyline to chamfer:
  3. Select a polyline.
    All vertices of the selected polyline are chamfered.
NOTE
When the chamfer method is distance-angle, the direction of the polyline defines which is the first entity of a vertex. See drawing rectangles for more information about the direction of closed polylines.
