Converting an entity into a polyline
Command: PEDIT
Lines and arcs can be converted into single-segment polyline.
  1. Do one of the following:
  2. Click the Edit Polyline tool button () on the Modify toolbar.
  3. Choose Edit Polyline in the Modify menu.
  4. Type editpline or pedit in the command window, then press Enter.
The command bar reads: Select polyline to edit.
Select a line or arc.
The command bar reads: The entity selected is not a polyline. Turn it into one? <Y>
A prompt menu displays:
  2. Press Enter to accept the default option.
  3. Choose Yes-Turn into polyline in the prompt menu.
  1. Press Enter to conclude the Edit Polyline command.
NOTE
The Explode tool turns a single segment polyline back into a line or arc.
