Exploring Blocks
Command: EXPBLOCKS
The Explblocks command opens the Blocks section of the Drawing Explorer dialog box (short for "explorer blocks").
In the Blocks Explorer you can:
Open the Blocks Explorer
To open the Blocks Explorer do one of the following:
go to top
The Blocks Explorer display options
You can choose between Detail View (list) and Icon View (thumbnails) to see the blocks in the current drawing.
Open the Detail View of the Blocks Explorer
Click the Detail View button () in the Drawing Explorer toolbar. The Detail View button is now pressed (), indicating the block details are displayed.
A preview of the selected block displays in the Preview sub-window of the Drawing Explorer.
Detail View of the blocks in the current drawing
go to top
Open the Icon View of the Blocks Explorer
Click the Icon View button () in the Drawing Explorer toolbar. The Icon View  button is now pressed (), indicating the block icons are displayed.
Icon View of the blocks in the current drawing
go to top
To rename a block
  1. Open the Blocks Explorer dialog.
  2. Select the block, then click the Block Name field.
  3. Type a new name in the Block Name field and press Enter.
