Command: DWGPROPS
The Dwgprops command opens the Drawing Properties dialog box, showing the general information and user defined properties stored with a drawing.
Drawing properties include: general information, summary, statistics and user defined custom properties.
Drawing properties can be referenced in a field in multiline text entities or tables.
To open the Drawing Properties dialog
do one of the following:
Choose Drawing Properties... in the File menu.
Type dwgprops in the command bar and press Enter.
Open the Drawing Properties dialog.
Open the Summary tab
page.
Fill out the property fields
Click the OK button.
Open the Custom tab
page.
Click the Add
button.
The Custom Property dialog
displays.
Type a name in the Name field.
The custom property name is listed under Document in the Field dialog.
Type a value in the Value field.
The value displays in
multiline texts where the custom property is inserted as a
field.
© Menhirs NV. All rights reserved. |
