Command: XTORUS
To create an X-Torus
  1. Do one of the following
  2. Click the Torus tool button () on the X-Solids toolbar.
  3. Choose Torus in the X-Solids menu.
  4. Type xtorus in the command bar, then press Enter.
The Create X-Solid Torus dialog displays:
  1. (option) Select Radius or Diameter from the option button of the X-field.
    The option applies to both the torus (X-field) and the tube (Y-field).
  2. To define the Parameters of the X-Solid torus do one of the following:
  3. Type the values in the Origin, X  and Tube Diameter Y  (or Tube Radius Y) fields.
  4. Select a value in the drop-down list.
  5. Click a Pick button () to define a parameter in the drawing.
  6. Click the Pick All button to define all parameters in the drawing.
  1. (option) Click the Manipulate... button to move or rotate the X-Solid torus.
  2. (option) Click the View... button to manipulate the view.
  3. (option) Click the Preview button.
  4. (option) Choose an After primitive creation operation to be executed after the X-Solid torus is created.
  5. Click the OK button to create the X-Solids torus.
