Installation, platforms and levels
Bricscad works on:
This help file describes all features. Some features do not apply to the Classic version; some commands are not supported on the Linux platform. Please see the Command Reference to check the availability of a command on the various platforms (Windows or Linux) and installation levels (Platinum, Pro or Classic).
Differences between platforms and levels
WINDOWS
LINUX
Platinum
Pro
Classic
Platinum
Pro
Classic
2D Constraints
ACIS Editing
No
No
Direct Modeling
No
No
X-Solids
No
No
No
No
No
X-Hardware
No
No
No
No
No
3D Constraints
No
No
No
No
Design Intent Recognition
No
No
No
No
Rendering
No
No
ActiveX, Including in-place-editing
No
No
No
Component Object Model (COM)
No
No
No
Visual Basic for Applications (VBA)
No
No
No
No
BRX
No
No
.NET
No
No
No
No
View the complete comparison chart on the Bricsys website.
NOTE
  • Bricscad comes as a single download file.
    Bricscad Classic, Pro or Platinum functionality will be activated according to your license key.
  • Bricscad can be installed in trial mode for a 30 day trial period.
    In trial mode, full Bricscad Platinum functionality will be activated (except VBA).
  • Each major upgrade (V11, V12, ...) is installed next to a previous version and can be installed in trial mode first.
  • VBA is installed only if you enter a Platinum or Pro license key during the first installation.
    See: To install VBA, when upgrading Bricscad Classic or after running Bricscad in trial mode.
To install VBA
If you have bought a Platinum or Pro license key, do the following to install VBA after running Bricscad in trial mode or when upgrading Bricscad Classic:
  1. Launch the Bricscad installer (e.g. Bricscad-Vxx.xx-en_US.exe).
  2. Choose the Modify option, then click the Next button.
  1. Accept the terms of the license agreement, then click the Next button.
  2. On the License Information dialog click the Modify... button.
  3. Enter your Platinum or Pro license key in the Key field on the Enter License Key for Bricscad dialog.
  4. Click the OK button to confirm the license key.
  5. On the next dialog, check the VBA checkbox in the features list, then click the Next button.
  1. Follow the next instructions of the installer software.
Related Topics:
Silent Installation
