Draws 3D mesh objects: boxes, cones, cylinders, dishes, domes, meshes, pyramids, spheres, tori, and wedges (short for "three dimensional").
command bar: 3d
: 3d
Wedge/Pyramid/Box/Cone/cyLinder/Sphere/DIsh/DOme/Torus/Mesh: (Enter an option.)
This command acts like a shell for the 3D mesh modeling commands.
Draws 3D wedges. See Ai_Wedge command.
Draws 3D pyramids. See Ai_Pyramid command.
Draws 3D boxes. See Ai_Box command.
Draws 3D cones. See Ai_Cone command.
Draws 3D cylinders See Ai_Cylinder command.
Draws 3D spheres. See Ai_Sphere command.
Draws 3D dishes (half spheres). See Ai_Dish command.
Draws 3D domes (half spheres). See Ai_Dome command.
Draws 3D tori (donuts). See Ai_Torus command.
Draws 3D meshes; prompts you:
First of four corners for polygon mesh - pick a point, or enter x,y,z coordinates. Second corner - pick a point, or enter x,y,z coordinates. Third corner - pick a point, or enter x,y,z coordinates. Last corner for mesh - pick a point, or enter x,y,z coordinates. Number of divisions along primary axis (between 2 and 256) - enter a number. Number of divisions along secondary axis (between 2 and 256) - enter a number. |
Ai_Dish - draws 3D dishes as mesh surfaces.
Ai_EdgeSurf and EdgeSurf - draws edge surfaces as mesh surfaces.
Ai_RevSurf and RevSurf - draws revolved surfaces as mesh surfaces.
Ai_RuleSurf and RuleSurf - draws ruled surfaces as mesh surfaces.
Ai_TabSurf and TabSurf - draws tabulated surfaces as mesh surfaces.
