Saves the drawing in DWF and other formats (short for "drawing Web format output").
DwfOut is an alias for the Export command
command bar: dwfout
menu bar: File | Export
: dwfout
Name the DWF file, and then choose a DWF format:
Compressed and binary formats create smaller files.
ASCII formats are readable by a larger number of programs.
Click Save.
DWF files can be viewed with the DesignReview software, available free from www.autodesk.com/designreview.
Names the DWF file. |
Specifies the format of DWF. Click the droplist, and then choose one of the following formats:
Saves the entire drawing in DWF format. Entities on frozen layers are not exported. |
Export - exports drawings in a variety of formats.
DxfOut - exports drawings in DXF format.
