Places multi-line text in drawings through a dialog box.
command bar: mtext
aliases: t, mt
menu bar: Draw | Multiline Text
toolbar: Draw | ![]()
: mtext
Multiline Text: First corner for block of text: (Pick a point, or enter x,y coordinates.)
Justification/Rotation/Style/Height/Direction/Width/<Opposite corner for block of text>: (Pick another corner, or enter an option.)
Displays a dialog box and text entry field:
Enter text, and then click OK.
Specifies the style. Choose a style name from the droplist. See Style command. |
Specifies the font. Choose a font name from the droplist; this overrides the font specified by the style. Bricscad can use any font installed on your computer.
To apply a font to just one or two words, highlight them, and then choose the font from the droplist, as illustrated below:
Specifies the text height. Choose a preset height from the droplist, or enter a value. To change the height of a few words, highlight them, and then specify the height. |
Toggles boldfacing of text. SHX fonts cannot be boldfaced. To apply boldfacing:
Toggles italicization of text. SHX fonts cannot be italicized. To apply italics:
Toggles underlining of text. To apply underlining:
Toggles overlining of text. To apply overlining:
Specifies the color of the text.
Specifies the angle by which to slant the text.
Specifies the width of characters.
Specifies the spacing between characters.
Undoes the last format applied.
Redoes the last undo. |
Stacks text containing special characters: / # or ^.
To stack fractions, follow these steps: 1. Enter fraction text, such as 3/4.
2. Highlight the fraction text.
3. Click the
4. Repeat steps 2 and 3 to unstack the fractions.
Inserts special symbols. Click the button, and then choose a symbol.
You can enter the symbols directly by typing their codes, such as %%d for the degree symbol. |
Inserts a field. |
Specifies the text justification (alignment) within the bounding box. Click the button, and then choose an alignment from the droplist.
The icon on the button indicates the current justification mode. |
Grips Editing
Mtext bounding boxes can be edited directly through grips:
Select the mtext. Notice that it has two grips.
Drag the left grip to move the mtext.
Drag the right grip to stretch the width of the bounding box (make it wider or narrower; the text reflows automatically to accommodate the change in width).
-MText - places paragraph text.
Text - places single-lines of text in drawings.
-Text - places text and evaluates LISP expressions.
AttDef - defines attribute text.
DdEdit - edits text.
Field - inserts a field in a multiline text, table cell or attribute.
Updatefield - Updates fields in selected Mtexts.
Style - creates and modifies text styles through the Drawing Explorer.
-Style - creates and modifies text styles through the command bar.
QText - toggles between text and rectangular representations.
Change - changes the position of text.
TxtExp - explodes text into polylines.
Spell - checks the spelling of text in drawings.
Find - finds and replaces text.
Properties - modifies the properties of text.
