Creates and modifies text style with the Drawing Explorer.
command bar: style
aliases: ddstyle, expfonts, expstyle, expstyles, st
menu bar: Tools | Drawing Explorer | Text Styles
status bar: Standard
: styles
Displays the Text Styles section of the Drawing Explorer:
Press F1 to access help.
Make changes to styles, or create new ones, and then click X to exit.
Designates the current text style. This is the style used by default in the Text and MText commands. |
Specifies the style name:
Specifies the height of the text. Enter 0 or a number larger than 0:
Specifies the width factor of the text. For example, entering 2 makes the text twice as wide. Enter a number larger or smaller than 1:
Specifies the obliquing angle for the text. For example, entering 15 slants the text forward by 15 degrees. Enter a positive or negative number:
Specifies the SHX or TTF font file to use; choose a name from the droplist:
Bricscad can use any SHX and TTF font found on your computer. |
Specifies style for TTF fonts; choose a stye from the droplist:
This property is not available for SHX fonts. |
Specifies the language for TTF fonts; choose one from the droplist:
Available languages may vary for each font. This property affects accents and other attributes specific to languages. This property is not available for SHX fonts; use Bigfont property instead. |
Lists the names of SHX bigfont files; choose one from the droplist:
"Bigfonts" is the name given to large SHX files that contain characters for multiple languages. This property is not available for TTF fonts; use Language property instead. |
Toggles backwards text. Backwards text is useful when text is plotted on the back of mylar or other clear media.
Toggles upside-down text.
Toggles vertical text. Only some SHX fonts support vertical text; TTF fonts cannot be drawn vertically, and so this option is not available for TTF fonts.
Toolbar Option |
Creates new text styles. The style is named "NewStyle1" and is given the default properties. To rename the style:
Erases the selected style. The current and Standard text styles cannot be erased. If the style is in use, displays dialog box:
Choose an option. |
Delete |
Caution! Erases the style, as well as all text that uses the style! |
Change |
Selects another style before erasing it. Entities using the doomed style are given the alternative that you select. Displays list of available styles:
The style is erased and text takes on the selected style. |
Cancel |
Cancels the operation; the style is not erased. |
Removes unused styles from the drawing. The following styles cannot be purged:
Shortcut Menu Options
Right-click layer names in Drawing Explorer to see the following shortcut menu:
Keystroke |
New |
Ctrl+N |
Creates new text styles. |
Delete |
Ctrl+D |
Deletes styles from Drawing Explorer. The following styles cannot be deleted:
Purge |
Ctrl+P |
Purges styles from the current drawing. The following styles cannot be purged:
Cut |
Ctrl+X |
Cuts the style and its properties to the Clipboard. |
Copy |
Ctrl+C |
Copies the style and its properties to the Clipboard. |
Paste |
Ctrl+V |
Pastes the style from the Clipboard into Drawing Explorer. |
Rename |
Renames the selected style. |
Select All |
Selects all styles. |
Set Current |
Specifies the current working style. Only one style can be current at a time. |
Right-click Standard (or other style name) on the status bar for the shortcut menu:
Shortcut Menu |
Standard |
Chooses the default text style. When the drawing contains additional text styles, their names are listed here. |
Properties
Opens the Text Styles section of the Drawing Explorer.
-Style - creates and modifies text styles through the command bar.
Text - places single-lines of text in drawings.
-Text - places text and evaluates LISP expressions.
MText and -MText - places paragraph text.
AttDef - defines attribute text.
DdEdit - edits text.
Change - changes the position of text.
TxtExp - explodes text into polylines.
Spell - checks the spelling of text in drawings.
Properties - modifies the properties of text.
