Allows to print a sheet list (= a list of model space or paper space layouts) to a printer. Saves a sheet list to a file.
command bar: publish
menu bar: File | Publish
: publish
Loads a saved sheet list. If the current list is not saved yet, you are prompted to save it. A File dialog displays. Select a *.dsd (Drawing Set Description) file, then double click or click the Open button. Choose whether to Replace the current sheet list or to Append the sheets in the *.dsd file to the current sheet list.
Saves the current sheet list to a a *.dsd (Drawing Set Description) file.
If checked, adds the model and paper space layouts of all open drawings. If not checkked, adds the model and paper space layouts of the current drawing only. Sets the value of the PUBLISHALLSHEETS system variable. |
Allows to choose the output target of the Publish command: Plotter named in page setup. |
Adds sheets to the current list. Displays a File dialog. Select a drawing. All layouts in the selected drawing are added to the sheet list. If a sheet name already exists, a dialog box displays prompting you to enter a new name.
Deletes the selected sheet(s) from the current list.
Drawing |
Path and name of the drawing of the currently selected sheet. |
Layout |
Layout name of the currently selected sheet |
Sheet List |
Layout name of the sheet. |
Page Setup name of the sheet. Click the down arrow on the list button to select a different page setup.
Name of the plot device as defined in the Page Setup of the sheet. |
Size of the paper in the currently selected page setup. |
Paper orientation in the currently selected
page setup: Landscape ( |
Scale of the currently selected page setup. |
Status of the currently selected page setup. |
Number of copies to create. |
If checked, a plot stamp is added. |
Click to setup the plot stamp. |
Publishes the current sheet set to the selected output target. |
Plot - plots drawings through the command bar.
Print - plots drawings through a dialog box.
