Exploding text
Command: TXTEXP
The TXTEXP command explodes Text and Mtext entities into 2D polylines.
To explode text
  1. Type txtexp in the command bar, then press Enter.
    The command bar reads: Select text to be exploded:
  2. Select a single text entity or multiple text entities, then press Enter.
    The selected text(s) are exploded.
NOTE
The solid fill of certain TTF fonts is removed when exploding such text, leaving the text outline only.
