Dimension Settings
A dimension style consists of six settings groups
To list the current status of the dimension variables
  1. Do one of the following:
  2. Click the Dimension Variable Status tool  button () on the Dimensions toolbar.
  3. Choose Dimension Variable Status in the Dimensions menu.
A list of all dimension variables displays in the command bar.
  1. Press the F2 function key to open the Bricscad Prompt History window.
  2. Press Enter to continue the listing.
  3. Press the F2 function key to close the Bricscad Prompt History window.
Lines and Arrows
Name
Settings
Variable
Arrow 1
DIMBLK1
Defines the arrow type for the arrow of the first dimension line (Dim line 1)
Arrow 2
DIMBLK2
Defines the arrow type for the arrow of the second dimension line (Dim line 2)
If DIMBLK2 equals DIMBLK2 it will be modified automatically when DIMBLK1 has changed.
Arrow size
DIMASZ
Sets the size of the arrows in drawing units.
Leader arrow
DIMLDRBLK
Defines the arrow type created by the Leader tool.
Dim line color
DIMCLRD
Sets the color of the dimension line.
Dim line LW
DIMLWD
Sets the line weight of the dimension line.
Dim line linetype
DIMLTYPE
Sets the line linetype of the dimension line.
Dim line ext
DIMDLE
Defines the extension of the dimension line beyond the extension lines, when arrowheads are set to oblique or architectural ticks.
Dim baseline spacing
DIMDLI
Sets the spacing of the dimension line for stacked baseline dimensions.
Dim line 1
DIMSD1
Controls the display of the first half of the dimension line, from the first extension line to the origin point of the dimension text.
Dim line 2
DIMSD2
Controls the display of the second half of the dimension line, from the origin of the dimension text to the second extension line.
Ext line color
DIMCLRE
Sets the color of the extension lines
Ext line LW
DIMLWE
Sets the line weight of the extension lines
Ext line ext
DIMEXE
Defines the extension of the extension lines beyond the dimension line.
Ext line offset
DIMEXO
Defines the offset of the extension lines from the dimension origin points
Ext line 1
DIMSE1
Controls the display of the first extension line.
Ext line 2
DIMSE2
Controls the display of the second extension line.
Ext line type 1
DIMLTEX1
Sets the linetype for the first extension line.
Ext line type 2
DIMLTEX2
Sets the linetype for the second extension line.
Ext line fixed
DIMLFXLON
Determines whether fixed length extension lines are used.
Ext line fixed length
DIMFXL
Specifies the length of the extension lines, measured from the dimension line (=  DIMEXE excl.), if DIMFXLON is on.
Center mark
DIMCEN
Defines the type of entity that will be created by the Dimcenter tool.
The options are: Mark, Line, None
Center mark size
DIMCEN
DIMCEN=0: no center mark, nor center lines are drawn
DIMCEN>0: a center mark is drawn, the value of DIMCEN defines the length of the center mark lines.
DIMCEN<0: a center mark and center lines are drawn; the abosolute value of DIMCEN defines the extension of the center lines outside the arc or circle and the gap between the center mark and the center lines.
Arc length symbol
DIMARCSYM
Controls how the arc symbol displays in an arc length dimension
Jog angle
DIMJOGANG
Specifies the angle of the oblique dimension line segment in jogged radius dimensions
NOTE
Dimension lines and extension lines are created in the current line type.
Text
Name
Settings
Variable
Text style
DIMTXSTY
Defines the text style of the dimension text.
Text color
DIMCLRT
Defines the color of the dimension text.
Text fill
DIMTFILL
Sets the dimension text background.
Left: Background = drawing window background color (BKGCOLOR).
Right: Color = color defined by DIMTFILLCLR.
Text fill color
DIMTFILLCLR
Defines the text background color
Text height
DIMTXT
Sets the height of the dimension text in drawing units.
Draw frame around text
DIMGAP
Toggles the text frame on/off. A frame is drawn if DIMGAP is negative.
In the Drawing Explorer > Dimensions settings dialog, the 'draw frame around text' option is enabled automatically when the value in the Text offset field changes from zero to a non-zero value.
Text offset
DIMGAP
Sets the offset distance around the dimension text and the distance between annotation and hook line created using the Leader command.
A negative value for DIMGAP draws a box around the dimension or annotation text.
If DIMTVP > 0, only negative values for DIMGAP (= draw text frame) make sense.
Text pos vert
DIMTAD
Defines the vertical text position with respect to the dimension line.
Text pos hort
DIMJUST
Defines the horizontal position of the text with respect to the extension lines.
Text offset vertical
DIMTVP
Sets the vertical position of dimension text above or below the dimension line when DIMTAD=0.
The offset equals the product of DIMTVP and the height of the dimension text (DIMTXT).
Text inside align
DIMTIH
Defines whether text that is placed inside the extension lines is aligned with the dimension line or placed horizontally.
Text outside align
DIMTOH
Defines whether text that is placed outside the extension lines is aligned with the dimension line or placed horizontally.
The vertical position of the dimension text is controlled through three settings variables: DIMGAP, DIMTAD and DIMTVP.
The scheme below illustrates the compound effect of these three settings variables:
Settings
Result
DIMGAP=0
DIMTAD=0
DIMTVP=0
DIMGAP=0.2
DIMTAD=0
DIMTVP=0
DIMGAP=-0.1
DIMTAD=0
DIMTVP=0
DIMGAP=0
DIMTAD=1
DIMTVP=0
DIMGAP=0.2
DIMTAD=1
DIMTVP=0
DIMGAP=-0.1
DIMTAD=1
DIMTVP=0
DIMGAP=0
DIMTAD=0
DIMTVP=1
DIMGAP=-0.1
DIMTAD=0
DIMTVP=1
Fit
Name
Settings
Variable
Arrow and text fit
DIMATFIT
Determines how text and arrowheads are placed if there is not enough room to fit both, text and arrowheads between the extension lines.
Text inside
DIMTIX
Forces text to be placed inside, arrowheads outside.
Dimline inside
DIMSOXD
Suppresses the dimension lines to be drawn outside the extension lines.
Text movement
DIMTMOVE
Specifies whether the dimension line moves with the text or that text can be moved independently. This setting also specifies if a leader needs to be drawn if the text is moved away from the dimension line.
Dim scale overall
DIMSCALE
Defines a scale factor for all entities in the dimension block.
Place text manually
DIMUPT
Allows to place text manually when creating the dimension block.
Dimline forced
DIMTOFL
Forces the dimension line to be drawn, even when the text is placed outside.
Primary Units
Name
Settings
Variable
Dim units
DIMLUNIT
Defines the unit type for the primary units.
Dim precision
DIMDEC
Sets the precision for the primary units.
Fractional type
DIMFRAC
Determines the fractional type if Dim Units is Fractional.
Decimal separator
DIMDSEP
Sets the decimal separator character
Dim round
DIMRND
Specifies the roundoff rule for linear dimensions. E.g. if set to 0.1, all dimensions will be rounded to the nearest 0.1 unit. If set to 0, dimensions are not rounded.
Dim prefix
DIMPOST
Text string placed in front of the dimension text.
Dim suffix
DIMPOST
Text string placed after the dimension text.
Dim scale linear
DIMFLAC
Scale factor for the primary units. E.g. if your drawing units are mm and you want your dimensions to be expressed in cm, set the scale factor to 0.1.
Suppress leading zeros
DIMZIN
Suppresses the zero that is placed before the decimal separator. If on, a distance of 0.0124 will display as .0124.
Suppress trailing zeros
DIMZIN
Suppresses trailing zeros in decimal values. If on, a distance of 125,00 displays as 125 and  82.50 displays as 82.5 if Dim Precision is 2.
Suppress zero feet
DIMZIN
Suppresses zero feet values in imperial units.
Suppress zero inches
DIMZIN
Suppresses zero inches values in imperial units.
Dim angle units
DIMAUNIT
Sets the unit for angular dimensions
Dim angle precision
DIMADEC
Sets the precision for angular dimensions
Suppress angle
leading zeros
DIMAZIN
Suppresses leading zeros in angular dimensions
Suppress angle
trailing zeros
DIMAZIN
Suppresses trailing zeros in angular dimensions
Alternate Units
Name
Settings
Variable
Alt enabled
DIMALT
Adds alternate units to the dimension text.
Alt units
DIMALTU
Sets the unit type for the alternate units.
Alt precision
DIMALTD
Sets the precision for the alternate units.
Alt scale factor
DIMALTF
Sets the scale factor for the alternate units. E.g. if the primary units are imperial and the alternate units are decimal (mm), then the alternate units scale factor must be set to 25.4.
Alt round
DIMALTRND
Roundoff rule for the alternate units in linear dimensions. E.g. if set to 0.1, alternate units will be rounded to the nearest 0.1 unit. If set to 0, alternate units are not rounded.
Alt prefix
DIMAPOST
Text string placed in front of the alternate dimension text.
Alt suffix
DIMAPOST
Text string placed after the alternate dimension text.
Alt suppress leading zeros
DIMALTZ
Suppresses the zero that is placed before the decimal separator in alternate units. If on, a distance of 0.0124 will display as .0124.
Alt suppress trailing zeros
DIMALTZ
Suppresses trailing zeros in decimal values in alternate units. If on, a distance of 125,00 displays as 125 and  82.50 displays as 82.5 if Dim Precision is 2.
Alt suppress zero feet
DIMALTZ
Alt suppress zero inches
DIMALTZ
Suppresses zero inch values in imperial units.
Tolerances
Name
Settings
Variable
Tolerance display
DIMTOL
Adds tolerances to dimension text. If DIMTOL is On, DIMLIM is switched Off.
Limits display
DIMLIM
Sets the default text to dimension limits. If DIMLIM is On, DIMTOL is switched Off.
Tolerance precision
DIMTDEC
Sets the precision for dimension tolerances.
Tolerance limit lower
DIMTM
Sets the lower limit for dimension tolerances.
Tolerance limit upper
DIMTP
Sets the upper limit for dimension tolerances.
Tolerance text height
DIMTFAC
Sets the text height for the tolerance settings with respect to the dimension text height. E.g. if set to 0.5, the tolerance text height is half the height of the dimension text.
Tolerance pos vert
DIMTOLJ
Determines the vertical position for dimension tolerances with respect to the dimension text.
Tolerance suppress leading zeros
DIMTZIN
Suppresses leading zeros.
Tolerance suppress trailing zeros
DIMTZIN
Suppresses trailing zeros.
DIMTZIN
DIMTZIN
Alt tolerance precision
DIMALTTD
Sets the precision for dimension tolerances in alternate units.
Alt tolerance suppress leading zeros
DIMALTTZ
Alt tolerance suppress trailing zeros
DIMALTTZ
Alt tolerance suppress zero feet
DIMALTTZ
Alt tolerance suppress zero inches
DIMALTTZ
