Commands: COPY, COPYCLIP, COPYBASE, PASTECLIP and PASTEBLOCK
You can duplicate entities within the current drawing using the Copy command. The default method is to create a selection set and then specify a starting point (base point) and an endpoint (second point) for the copy. You can also specify the displacement as a direction vector (X,Y,Z).
Depending on the COPYMODE system variable you can create multiple copies of the selection set or just one.
Copybase and Pasteblock pastes the selection as a block.
The Copy option of the Grips Editing commands allows to create multiple copies of the entities being stretched, moved, rotated, mirrored or scaled.
Do one of the following:
Click the Copy
tool button () on the Modify toolbar.
Choose Copy in the Modify menu.
Type copy or CO in the command bar.
The command bar reads: Select entities to copy:
Select the entities, then right click or press Enter.
If Copy Mode is Multiple:
The command bar reads: Enter base point:
mOde/<Displacement>:
If Copy Mode is Single:
mOde/Multiple/<Displacement>:
Specify the base point.
The selection set is now attached to the cross hairs.
The command bar reads: Enter second point: <Enter to use the
base point as displacement>:
Click the second point.
Use Direct
Distance Entry: type the displacement distance, then press
Enter.
The distance is measured in the cursor direction.
Use ORTHO or
POLAR
TRACKING to constrain the movement of the cross hairs.
Press <Enter>: the first point is
interpreted as a relative X,Y,Z displacement.
E.g. if the coordinates of the base point are 2,3,0, the selection
set is copied 2 units in the X direction and 3 units in the Y
direction from their current position.
The selection set is copied.
If Copy Mode is Single, the copy command is completed.
If Copy Mode is Multiple, you are prompted to create the next copy. See To make multiple copies.
Click the Copy
(Option) If Copy Mode is Single, do one of the following:
Choose Multiple in the prompt menu
Type M, then press Enter
The command bar reads: Enter base point: mOde/<Displacement>:
Do one of the following to specify the second point.
Type the displacement distance, then press
Enter.
Use ORTHO or
POLAR
The first copy of the selection set is created.
The command bar reads: Enter second point: Undo/Exit:
Repeat step 5 to create additional copies.
Right click, choose Exit in the prompt menu or press Enter to stop.
Choose Undo in the prompt menu or type U in the command bar, then press enter to delete the previous copy of the selection set.
To paste a selection set as a block
Choose Copy with Base Point in the Edit menu.
Type copybase in the command bar, then press Enter.
Press and hold the Ctrl en Shift keys, then press C.
The command bar reads: Select base point:
Specify the base point (origin point).
The command bar reads: Select entities to copy to the
clipboard:
Select the entities.
Press Enter to conclude the selection of entities.
Choose Paste as Block in the Edit menu.
Type pasteblock in the command bar, then press Enter.
Press and hold the Ctrl and Shift keys, then press V.
The selection set is attached to the cursor.
The command window reads: Select insertion point.
Specify the insertion point.
The selection is pasted as a block.
(option) Repeat steps 5 and 6 to paste another copy as a block.
NOTE |
If you paste multiple copies of the same selection set, each block is named differently. |
© Menhirs NV. All rights reserved. |
