Plots drawings to printers and to files, through prompts at the command bar; this command is meant for scripts and routines.
command bar: plot
alias: -plot
: plot
Detailed plot configuration Yes/<No>: (Type Y or N.)
Enter a layout name or [?] <Model>: (Enter a name, type ? for a list of layout names, or press Enter to accept the default).
Enter a page setup name: (Enter a name, or press Enter for none).
Enter an output device name or [?] <default.pc3>: (Enter a name, type ? for a list of device names, or press Enter to accept the default).
Write the plot to a file <Yes>/No: (Type Y or N).
Save changes to model tab Yes/<No>: (Type Y or N).
Proceed with Plot <Yes>/No: (Type Y or N).
Using default plot configuration (default.pc3).
Detailed plot configuration:
Enter an output device name or [?] <dfault.pc3>: (Enter a name, type ? for a list of device names, or press Enter to accept the default).
Enter paper size or [?] <Letter>: (Enter a name, type ? for a list of size names, or press Enter to accept the default).
Enter paper units <Inches>/Millimeters: (Type I or M).
Enter drawing orientation <Portrait>/Landscape: (Type P or L).
Plot upside down Yes/<No>: (Type Y or N).
Enter plot area <Display>/Extents/Limits/View/Window: (Enter an option).
Enter plot scale (Plotted Inches = Drawing Units) or <Fit>: (Enter a scale factor or type F).
Enter plot offset (x,y) or <0.0000,0.0000>: (Enter x,y offset distance).
Plot with plot styles Yes /<No>: (Type Y or N).
Enter plot style table name (enter . for none) or [?] <bricscad.stb>: (Enter a name, type ? for a list of style names, or press Enter to accept the default).
Plot with lineweights <Yes>/No: (Type Y or N).
Remove hidden lines Yes/<No>: (Type Y or N).
To configure plots with a dialog box, use Print command.
Toggles detailed plot configuration:
Specifies the name of the layout to plot.
Specifies the name of a page setup. Enter a name, or press Enter for none. See PageSetup command. |
Specifies the PC3 file for the output device.
When the default is None, you must specify another name. |
BricsCAD displays the Create Plot File dialog box.
Specify a file name, and then click Save.
or |
Toggles saving the plot parameters to the model or layout tab:
Toggles plotting of the drawing:
Detailed Configuration Option |
Enter a layout name |
Enter an output device name |
Specifies the name of the paper size:
Specifies the units used for paper sizes:
Determines how the drawing is plotted on the paper:
Toggles upside-down plotting:
Specifies the area of the drawing to plot:
Enter view name - specify the name of a view.
Select first corner of window - specify one corner of the rectangle. Select second corner of window - specify the other corner. |
Specifies the plot scale factor:
Specifies the offset distance for the print. Enter positive or negative distances to move the drawing in the x and/or y distances:
The lower left corner of the drawing is moved by the specified distance. This is useful when the paper has a title block area that might interfere with the drawing. |
Toggles the use of plot styles:
Plot styles override lineweight settings. |
Enter plot style table name |
Specifies the plot style table to use, which assigns properties to "pens," colors, and entities.
Toggles the use the lineweights:
This option is unavailable when Plot with Plot Styles is turned on. |
Toggles removal of hidden lines for 3D drawings:
Write the plot to a file |
BricsCAD displays the Create Plot File dialog box. Specify a file name, and then click Save.
Save changes to model tab or Save changes to layout-name |
Proceed with Plot |
Print - plots drawings through a dialog box.
QPrint - plots drawings using the current settings.
Preview - previews drawings before they are plotted.
ConvertPStyles - converts drawings from CTB to STB plot styles.
Layer - assigns plot styles to layers.
PlotStyle - sets the current plot style.
Publish - allows to print a sheet list (= a list of model space or paper space layouts) to a printer. Saves a sheet list to a file.
