Ends BricsCAD; optionally saves unsaved drawings.
command bar: quit
shortcuts: Ctrl+Alt+Q, Alt+F4
alias: exit
menu bar: File | Exit
: quit
If no drawings need to be saved, exits without displaying any dialog boxes or prompts in the command bar.
If drawings are unsaved, displays a dialog box:
Saves the drawing, and then exits BricsCAD. |
Does not save the drawing, and then exits BricsCAD. |
Cancels the command; BricsCAD does not exit. |
Open - opens drawing files.
Close - closes the current drawing.
WClose - closes the current window.
