Creates freehand sketches.
command bar: sketch
alias: freehand
menu bar: Draw | Sketch
toolbar: Draw | ![]()
: sketch
Sketch: Length of segments <0.1000>: (Enter a number, identify two points or press Enter to accept the default.)
Press ENTER or click to toggle Pen/Quit without save/Record (save)/Erase/Connect/Straight/eXit with save:
Click to start sketching, click again to toggle pen up/down.
Enter an option, or press X followed by Enter to exit command.
During sketching, the lines are green until the sketch lines are saved:
Saving sketch lines ...
Depending of the status of the SKPOLY system variable sketches are made from lines or polylines.
Specifies the length of segments. Enter a number. Too small a segment length results in large drawings. |
Allows you to move the pen without drawing.
Exits the command without saving the sketch. |
Saves the sketch; reports: Saving sketch lines. Continue sketching. |
Erases the sketch lines from their endpoints interactively. Click to stop erasing and restart sketching.
Connects cursor to end of the last segment; prompts you: Point cursor to end of last sketch line - move the cursor to the end of the last sketch. This option is meant for use after a pen up. |
This option works only when the pen is up. Draws a straight segment to the current cursor location .
Saves the sketch; reports: Saving sketch lines. Exits the sketch command. |
Procedures
Setting the Sketch Poly (SKPOLY) system variable
PLine - draws polyline segments and arcs.
RevCloud - draws revision clouds.
