Stretches entities.
command bar: stretch
alias: s
menu bar: Modify | Stretch
toolbar: Modify | ![]()
: stretch
Select entities to stretch by crossing-window or crossing-polygon: (Pick a point, or enter C or CP.)
Opposite Corner: (Pick another point.)
This command works only with crossing selection modes.
Entities in set: 1
Select entities to stretch by crossing-window or crossing-polygon: (Choose more entities, or press Enter to continue.)
Base point of displacement: (Pick a point, or enter x,y coordinates.)
Second point of displacement: (Pick another point.)
Text cannot be stretched.
Procedures
To stretch entities using grips
Lengthen - changes the length of open entities.
Extend - extends open entities.
Scale - changes the size of entities.
Properties - changes the geometry of entities.
