Places single lines of text in the drawing, and optionally evaluates LISP expressions.
command bar: -text
alias: -t
: -text
Text: Style/Align/Fit/Center/Middle/Right/Justify/<Start point>: (Pick a point, or enter an option.)
Height of text <0.2000>: (Specify a height, or press Enter to accept the default.)
Rotation angle of text <0>: (Specify an angle, or press Enter to accept the default.)
Text: (Enter text, and then press Enter.)
When the TextEval system variable is set to 1, this command evaluates LISP expressions:
Text: Style/Align/Fit/Center/Middle/Right/Justify/<Start point>: (Pick a point.)
Height of text <0.2000>: (Press Enter.)
Rotation angle of text <0>: (Press Enter.)
Text: (* pi 2)
The result of the equation (pi x 2) is placed as text:
Specifies the starting point of the text. Pick a point, or enter x,y coordinates. The starting point is affected by the justification. |
Specifies the name of the text style; prompts you: Text style to use (or '?') - enter the name of a style or type ?. See Style command. |
Lists the names of styles found in the drawing; prompts you: Text style(s) to list - specifies the styles to list.
Specifies align justification. Aligns text between two points; prompts you: Text start point - specify the staring point of the text. Text end point - specify the end point for the text.
This option supresses the height and angle prompts, because the height and angle are determined by the two pick points.
More characters in the same distance make the text shorter.
Specifies fit justification. Fits text between two points and prompts for the height; prompts you: Text start point - specify the staring point of the text. Text end point - specify the end point for the text. Height of text - specify the text height.
This option supresses the angle prompt, because the angle is determined by the two pick points. Entering certain heights can cause the text to be excessively elongated or squeezed. Use this justification to force text to fit in an area, such as a closet.
Specifies center justification. Centers text in the middle of the baseline; prompts you: Center point of text - specify the center point on the baseline.
Specifies middle justification. Centers text on the middle of the text; prompts you: Middle point of text - specify the middle point.
Specifies right justification. Right-justifies each line of text; prompts you: Right point of text - specify the right point on the baseline.
Displays all justification modes; prompts you: Text: Style/Align/Fit/Center/Middle/Right/TL/TC/TR/ML/MC/MR/BL/BC/BR/<Start point> - enter an option.
Specifies the height of the text. Enter a number or pick two points. This prompt is not displayed under the following conditions:
Specifies the angle of the text. Enter a number or pick two points. This prompt is not displayed when the justification is set to Align or Fit. |
Specifies the text. Enter a line of text, and then press Enter. The prompt repeats; enter more text. Each additional line of text is positioned under the previous line.
Exit the command by pressing Enter at the 'Text' prompt. |
Procedures
Defining text system variables
Grips Editing
Text can be moved directly through grips:
Select the text face. Notice that it has one grip at its insertion point.
Drag the grip to move the text.
Aligned and fitted text have two grips:
One grip moves the text.
The second grip stretches and rotates the text. Aligned text also changes its height.
Text - places single-lines of text in drawings.
MText and -MText - places paragraph text.
AttDef - defines attribute text.
DdEdit - edits text.
Style - creates and modifies text styles through the Drawing Explorer.
-Style - creates and modifies text styles through the command bar.
QText - toggles between text and rectangular representations.
Change - changes the position of text.
TxtExp - explodes text into polylines.
Spell - checks the spelling of text in drawings.
Properties - modifies the properties of text.
Find - finds and replaces text.
