Works with BricsCAD (Windows) Pro and Platinum, BricsCAD (Linux) Pro and Platinum
Performs Boolean union operations on 3D solids and 2D regions; adds one to another to form a single entity.
command bar: union
alias: uni
menu bar: Model | 3D Solid Editing | Union
toolbar: 3D Solid Editing |
: union
Select ACIS objects to union: (Choose one or more 3D solids and/or 2D regions.)
Entities in set: 2
Select ACIS objects to union: (Choose more ACIS entities, or press Enter to complete the command.)
The resulting solid takes on the properties of the first-picked solid.
3D solids that are joined through the Union command often look no different after the operation:
This command also applies to regions:
Specifies the ACIS entities to join into a single entity. Choose one or more 3D solids and/or 2D regions. The resulting entity takes on the properties of the ACIS entity selected first. This command also joins regions and 3D solids into a single entity. |
XIntersect - Performs Boolean intersection operations on Acis solids and X-Solids; removes all but common portions.
XSlice - Cuts an ACIS solid or an X-solid with a plane; the result is a 3D solid cut in two. You can choose whether to keep both parts or just one.
XSubtract - Performs Boolean subtraction operations on Acis solids and X-Solids; removes one from the other.
XUnion - Performs Boolean union operations on Acis solids and X-Solids; adds one to another to form a single entity.
XCut - Trims or cuts ACIS solids and X-Solids using 2D profiles as cutting tools.
XPunch - Cuts ACIS solids and X-Solids using 2D profiles as cutting tools.
XTrim - Trims ACIS solids and X-Solids using 2D profiles as cutting tools.
