Works with BricsCAD (Windows) Platinum
Extrudes 2D entities along a path to X-solids.
command bar: xsweep
menu bar: Model | X-Solids (History Based) | Sweep
toolbar: X-Solids | ![]()
: xsweep
Select profiles to sweep: select one or more closed 2D entities.
Non-selfintersecting closed polylines, circles and ellipses are accepted.
Right click to stop selecting entities.
Select path: select an open or closed linear entity.
Lines, 2D polylines, 3D polylines, circles, arcs, ellipses, elliptical arcs and splines are accepted.
The Create Swept X-Solid dialog box temporarily
closes. |
Absorb Path |
If checked, deletes the extruded 2D entities and the sweep path. |
Launches the XUnion, XIntersect or XSubtract command to be executed using the newly created X-Solid box. You are prompted in the command bar to select one or more other solids. |
Displays a preview of the extrusion in the drawing in dashed lines. |
The Create Swept X-Solid dialog box temporarily closes. Displays the View Options dialog box:
Creates the X-Solid. |
Aborts the XSweep command. |
Procedures
XBox - creates a three-dimensional X-Solid box.
XCone - creates a cone as a 3D X-solid.
XCylinder - creates a cylinder as a 3D X-Solid.
XExtrude - extrudes 2D entities to X-solids.
XRevolve - revolves 2D closed entities to turn them into 3D X-Solids.
XSphere - creates a sphere as a 3D X-Solid.
XTorus - creates a torus as a 3D X-Solid.
XWedge - creates a wedge as a 3D X-Solid.
