Works with BricsCAD (Windows) Platinum
Creates a cone as a 3D X-Solid.
command bar: xcone
menu bar: Model | X-Solids (History Based) | Cone
toolbar: X-Solids | ![]()
: xcone
Specifies the x,y,z coordinates of the origin point:
Specifies the radius or the diameter of the base face of the cone. Click the button to switch.
Specifies them minor radius in case of an elliptical cone.
Specifies the radius of the top face of the cone.
Specifies the height of the cone:
Enables the Minor Radius Y field. |
The Create X-Solid Cone dialog box temporarily closes. Prompts you in the command bar:
Elliptical:
Displays a preview of the cone in the drawing in dashed lines. |
The Create X-Solid Cone dialog box temporarily closes. Displays the View Options dialog box:
The Create X-Solid Cone dialog box closes. Displays the Manipulate dialog box to Move, Rotate or Align the X-Solid cone.
Move: Prompts you in the command bar to specify the displacement vector by clicking two points. Move To: Prompts you in the command bar to move the origin point of the X-Solid cone. Rotate: Type an angle in the Angle field or choose an angle in the list box, then click an axis button to rotate the X-Solid cone. Align: Aligns the X, Y or Z-axis of the X-Solid box. Prompts you in the command bar to specify two points. The X-Solid cone is rotated about its origin. Done: Creates the X-Solid cone. OK: Reopens the Create X-Solid cone dialog box. Cancel: Aborts the XCone command. |
Creates the X-Solid cone. |
Launches the XUnion, XIntersect or XSubtract command to be executed using the newly created X-Solid cone. You are prompted in the command bar to select one or more other solids. |
Grips Editing
X-Cones can be edited directly through grips:
Select the cone.
Drag the grip to move the cone.
Procedures
XBox - creates a three-dimensional X-Solid box.
XCylinder - creates a cylinder as a 3D X-Solid.
XExtrude - extrudes 2D entities to X-solids.
XRevolve - revolves 2D closed entities to turn them into 3D X-Solids.
XSphere - creates a sphere as a 3D X-Solid.
XSweep - Extrudes 2D entities along a path to X-solids.
XTorus - creates a torus as a 3D X-Solid.
XWedge - creates a wedge as a 3D X-Solid.
