BricsCAD is available with three types of commercial licenses combined to two platforms and three feature levels:
Commercial licenses: Single, Volume, Network
Platforms: Windows, Linux
Feature levels: Classic, Pro, Platinum
See also the differences between platforms and between levels.
BricsCAD can also run in trial mode for evaluation.
Run your BricsCAD trial as Classic, Pro or
Platinum![]()
All your valid licenses can be viewed on the Bricsys website.
Go to the Bricsys website
In the Support menu,
choose My Account (login required).
Make sure you have the Bricsys account which contains your
licenses. Contact your Bricsys account manager if needed.
The My Account page opens.
In the left menu, choose Licenses and support contracts.
All your active licenses are displayed.
(Optional) Click a license to see its details.
Direct link : View my licenses
Depending on the type and status, licenses can be activated, modified and deactivated.
Use the activation to:
Activate a trial.
Activate a Single or Volume license.
Use a Network license (beforehand activated on a network license server).
Use the modification to:
Upgrade a license (e.g. from Single Classic to Single Platinum).
Replace a license (e.g. a Single Classic by a Network Pro).
Use the deactivation to:
Migrate a license to another computer.
Deactivate a license.
Be able to reactivate a license after installing a new hard disk, changing partitions or upgrading the operating system.
