3dFace
Draws 3D 4-edged faces with optional invisible edges.
command bar:  3dface
aliases:  3f, face
menu bar: Model | Meshes | 3D Face
toolbar:  Meshes | 3D Faces |
: 3dface
Invisible edge/<First point of 3D face>: (Pick a point, or type I.)
Invisible edge/<Second point>: (Pick a point, or type I.)
Invisible edge/<Third point of 3D face>: (Pick a point, or type I.)
Invisible edge/<Last point>: (Pick a point, or type I.)
Invisible edge/<Third point of 3D face>: (Press Enter to exit the command.)
This command repeats the 'Invisible edge/<Third point of 3D face>' prompt so that adjoining faces can be drawn:
Specifies the location of the first corner of the face.
Pick a point, or enter x,y,z coordinates.
Second point
Specifies the location of the second corner of the face.
Specifies the location of the third corner of the face.
Last point
Specifies the location of the fourth corner of the face.
Invisible edge
Makes the next edge invisible; prompts you:
Third point of 3D face - specify a point for the next vertex.
Grips Editing
3D faces can be edited directly through grips:
  1. Select the 3D face. Notice that it has several grips.
  2. Drag a grip to stretch the face.
3dMesh - draws 3D surface meshes of size m x n.
PEdit - edits 3D meshes.
PFace - draws 3D multi-sided meshes.
