3dMesh
Draws 3D surface meshes.
command bar:  3dmesh
alias:  mesh
menu bar: Model | Meshes | Polygon Mesh
toolbar:  Meshes | 3D Face |
: 3dmesh
Number of vertices in M direction (between 2 and 256): (Enter a number.)
Number of vertices in N direction (between 2 and 256): (Enter a number.)
Position of vertex (0, 0): (Pick a point, or enter x,y,z coordinates.)
Vertex (3, 4): (Pick another point, or enter x,y,z coordinates.)
Specifies the number of vertices in the primary direction.
Enter a number between 2 and 256.
A single face is made from a 2x2 vertex.
Specifies the number of vertices in the secondary direction.
Position of vertex (n, n)
Specifies the position of the vertex.
Grips Editing
3D meshes can be edited directly through grips:
  1. Select the 3D mesh . Notice that it has several grips.
  2. Drag a grip to stretch the mesh.
3dFace - draws 3D 4-edged faces with optional invisible edges.
PEdit - edits 3D meshes.
PFace - draws 3D multi-sided meshes.
