Customizes the user interface of BricsCAD: menus, toolbars, keyboard shortcuts, aliases, and shell commands.
For full details on using this command, see Customizing BricsCAD in the User Guide.
command bar: customize
alias: cui
menu bar: Tools | Customize
: customize
Create or modify a user interface elements, and then click OK.
For details on using this dialog box, see the "Customizing BricsCAD" ebook.
Options |
Specifies the CUI file that defines the menu, toolbar, and keyboard customization. Aliases and shell commands are defined in a PGP file. |
Returns all user interface elements to their out-of-the-box state. Displays the Revert to Defaults dialog box:
This button is handy when you make a big mistake with customization. |
Reset toolbars, menus, and keyboard shortcuts |
Overwrites the default.cui file the default installed originally by BricsCAD. |
Reset aliases and shell commands |
Overwrites the default.pgp file the default installed originally by BricsCAD. |
Shortcut Menu |
Right-click a menu item:
Insert Item |
Adds an item to the menu. |
Insert Submenu |
Adds a submenu to the menu. |
Insert Separator |
Inserts a separator line between menu items. |
Delete |
Erases the selected menu item. |
Menu Item |
Title |
Specifies the name displayed by the menu item. Prefix a letter with & to create an Alt-key shortcut, such as &Line. |
Diesel |
Specifies the Diesel code to be employed by the menu item. |
Tool ID |
Identifies the menu item to other elements in the CUI file. (The Tool ID is assigned by BricsCAD.) |
Help |
Specifies the help string displayed on the status bar. |
Command |
Specifies the command(s) or macros. |
Image |
Specifies the image to display next to the menu item; click ... to access the file dialog box. |
Shortcut Menu |
Right-click a toolbar item:
Insert Tool |
Inserts a new button in the selected toolbar. |
Insert Control |
Inserts a control (droplist). |
Insert Flyout |
Inserts a flyout (sub-toolbar). |
Insert Separator |
Inserts a separator line. |
Delete |
Erases the selected toolbar button. |
Toolbar Button |
Title |
Names the toolbar button; displayed by the tooltip. |
Diesel |
Specifies the Diesel code to be employed with the button. |
Tool ID |
Identifies the toolbar item to other elements in the CUI file. (The Tool ID is assigned by BricsCAD.) |
Help |
Command |
Image |
Specifies the image to use for the toolbar button; click ... to access the file dialog box. |
To assign a different command to a keyboard shortcut, select a command in the right and pane, then drag the command to the keyboard shortcut in the left hand pane. |
Shortcut Menu |
Right-click a keyboard shortcut:
Insert Shortcut |
Adds a new keyboard shortcut to the list; displays dialog box:
Select Available Tool |
Assigns an existing command to the keyboard shortcut. |
Create New Tool |
Assigns a new command/macro to the shortcut. |
Toolbox |
Specifies the toolbox to which to add the new command; click the droplist, and then choose a toolbox. |
Title |
Names the new tool. |
Help |
Specifies the help text. |
Command |
Image |
Specifies the name of the image file; click ... to access the file dialog box. |
Delete Shortcut |
Erases the selected shortcut. |
Keyboard Shortcut |
Key |
Specifies the keyboard shortcut. |
Tool ID |
Identifies the keyboard shortcut to other elements in the CUI file. (The Tool ID is assigned by BricsCAD.) |
Help |
Specifies the text of the help string, even though help strings are not displayed by keyboard shortcuts. |
Command |
Specifies the command(s) to associate with the keyboard shortcut. |
Image |
Specifies the image to associate with the command, even though images are not used with keyboard shortcuts. |
Shortcut Menu |
Insert quad item group |
Delete quad item group |
Select the Quad item group you want to delete. |
Append item |
Adds a new menu item. |
Quad Group Order |
Controls the display and the order of the Quad item groups.
On Switch |
Sets the commands to be executed when switching to the workspace. To ad a command, do one of the following:
Context Menu |
Insert workspace |
Creates a new workspace. |
Insert separator |
Inserts a separator before the selected workspace. |
Delete |
Deletes the selected workspace. |
Add |
Adds an alias; displays a dialog box:
Alias |
Specifies the name of the alias, a command abbreviation. |
Command |
Specifies the command to which the alias is assigned. |
Edit |
Edits the selected alias. |
Delete |
Erases the selected alias. |
Add |
Adds a shell command; displays the following dialog box:
Shell commands run programs external to BricsCAD. |
Alias |
Specifies the name of the shell command; this is the command you enter at the ' : ' prompt. |
Shell Command |
Specifies the operating system command to execute, or program to run. To run a program, use the Start prefix, as in Start Notepad.exe. |
Prompt |
Specifies the prompt to display in the command bar, such as "Enter file to edit:" |
Flags |
Determines how the shell command operates: Don't Wait - BricsCAD immediately returns to the command prompt without waiting for the application to finish. Minimized - the application runs minimized. Hidden - the application does not appear on the screen. Quotes - the shell command uses quotations when the command string uses spaces, such as "C:\cad programs\file name.exe". |
Edit |
Edits the selected shell command. |
Delete |
Removes the selected shell command. |
AddInMan - loads and unloads VBA functions through a dialog box.
AppLoad - selects external routines to load when BricsCAD starts.
Commands - lists the names of internal and external commands.
CuiLoad and CuiUnload - loads and unloads menu files.
MenuLoad and MenuUnload - loads and unloads menu files.
Netload - loads a .NET application.
ProfileManager - allows to set current, create, copy, delete, import and export user profiles through a dialog box.
ToolPalettes - opens the Tool Palettes bar.
VbaLoad and -VbaLoad - loads VBA projects.
VbaRun and -VbaRun - runs VBA macros.
VbaIde - opens the VBA integrated development environment.
VbaMan - manages VBA projects.
VbaUnload - unloads VBA projects.
