DSettings
Displays the Settings dialog box for drafting settings  (short for "drafting settings").
command bar:  dsettings
transparent:  'dsettings
alias:  settings
: dsettings
Displays the Settings dialog box at the Drafting section:
Change settings, and then click X.
Coordinate Input
Orthogonal Mode
Toggles orthogonal mode:
  • On - constrains cursor movement to the vertical and horizontal.
  • Off - moves cursor freely.
Hold down the Shift key to turn on ortho mode temporarily; alternatively, double-click ORTHO on the status bar.
Tablet Mode
Toggles tablet mode:
  • Digitizing mode - uses tablet for drawing input.
  • Command selection mode - uses tablet for command input.
Snap/Grid
Grid Mode
Toggles the grid display:
  • On - displays the grid.
  • Off - does not display the grid.
To toggle the grid display, you can click GRID on the status bar.
Grid Unit
Specifies the spacing between grid dots:
  • X - specifies the distance in the x direction.
  • Y - specifies the distance in the y direction.
Grid Major
Specifies the frequency of manor gridlines versus minor gridlines.
Grid Display
Specifies how the grid is displayed.
  • Display beyond limits area: If checked, the grid displays on the entire drawing.
  • Adaptive grid display:  If checked, the number of grid lines is adapted to the zoom. Otherwise the grid does not display if the grid is too dense. A warning displays in the command bar: "The grid spacing is too small to display in this view".
  • Allow subdivision below grid spacing: If checked, extra grid lines display when zooming in closely.
  • Follow dynamic UCS: If checked, the grid displays in the XY-plane of the dynamic UCS (not yet implemented).
Grid Style
Specifies whether the grid is displayed with dots or lines in Model Space, Block Editor and/or Layouts.
Grid Axis Color
Sets the color of the grid lines on the X-axis and Y-axis of the current coordinate system; default = index color 251.
Grid Major Color
Sets the color of the major grid lines; default = index color 252.
Grid Minor Color
Sets the color of the minor grid lines: default = index color 253.
Grid XYZ tint
Specifies whether the grid axis lines, the major grid lines and/or the minor grid lines display in the color of the X-axis (COLORX) and the Y-axis (COLORY).
Snap Angle
Rotates the snap and grid relative to the current UCS.
Snap Base
Locates the origin of the snap and grid relative to the current UCS:
  • X - specifies the x coordinate.
  • Y - specifies the y coordinate.
Snap Isometric Pair
Specifies the current isometric plane:
  • Left.
  • Top.
  • Right.
Snap Mode
Toggles snap mode:
  • On - constrains cursor movement to the snap distance.
  • Off - allows cursor to move freely.
To toggle snap mode, click SNAP on the status bar.
Snap Style
Specifies the snap style:
  • Rectangular snap - sets snap and grid to rectangular.
  • Isometric snap - sets snap and grid to isometric; adds the Isocircle option to the Ellipse command.
Snap Type
Specifies the snap type:
  • Grid snap - restricts cursor movement to x and y snap distances.
  • Polar snap - restricts cursor movement to angles.
Snap Unit
Specifies the spacing between snap points:
Entity Snap Coordinates
Determines whether coordinates entered by the keyboard have priority over entity snaps:
  • Entity snap settings override keyboard coordinate entry.
  • Keyboard entry overrides entity snap settings.
  • Keyboard entry overrides snap settings except in scripts.
Ignore Entity Snap Elevation
Replaces the Z-coordinate of an entity snapping point with the current value of the ELEVATION system variable.
Polar Distance
Specifies the polar distance; effective only when Snap Type is set to Polar Snap.
DdSetVar - changes the values of system variables through a dialog box.
SetVar - changes system variables through the command bar.
