Inserts images in drawings through the Drawing Explorer.
command bar:  image
aliases:  expimages, im
menu bar:  Tools | Drawing Explorer | Images
toolbar:  Images |
: image
Displays the Drawing Explorer open to the Images node:
Attach image files, or modify their properties,and then click X.
Press F1 to access help.
New
Attaches raster image files to the drawing; displays the Open dialog box.
Choose a raster file, and then click Open.
BricsCAD displays the Images dialog box. See ImageAttach command.
Delete
Erases the image from the drawing.
You may need to use the Regen command to update the screen.
Insert
Inserts the image in the drawing; displays the Images dialog box. See ImageAttach command.
Cut
Cuts the image to the Clipboard. You can paste it in the Drawing Explorer's Image section of another drawing. It is removed from the current drawing.
Copy
Copies the image to the Clipboard. You can paste it in the Drawing Explorer's Image section of another drawing.
Paste
Pastes images and related data.
Regen
Updates the drawing to reflect changes made in this dialog box.
Regen Toggle
Toggles automatic drawing updates:
  • On - updates drawing automatically.
  • Off - updates drawing only when the Redraw button is clicked.
Details
Displays the details of each image.
Icons
Displays the image files as small icons, hiding their details. This is useful when a drawing contains many images.
Tree
Displays the relationship between files in an Explorer tree-like fashion. "Current" refers to the current drawing.
Name
Specifies the name of the image. This is usually the image's file name.
Loaded
Toggles whether the image is displayed:
  • On - displays the image in the drawing.
  • Off - does not display the image in the drawing; the image frame is visible, unless turned off by the ImageFrame command.
Size in Pixels
Reports the size of the image in pixels, horizontally and vertically.
References
Reports the number of times the image occurs in the drawing.
Saved Path
Specifies the path to the image file.
Click the ... button to change the path.
Found Path
Reports the path to the image file.
Grips Editing
Images can be edited directly through grips:
  1. Select the image. Notice that its frame has four grips.
  2. Drag a grip to stretch (resize) the image.
Procedures
Open the Images Explorer
Images Explorer display options
Placing images in a drawing
To load / Unload images
Detaching images
-ImageAttach - attaches raster images to the drawing; displays prompts in the command bar.
ImageClip - clips images.
