ImageQuality
Toggles the quality of images between draft and high.
command bar:  imagequality
transparent:  'imagequality
menu bar: Modify | Raster Image | Image Quality
toolbar:  Images |
: imagequality
Enter image quality setting [Draft/High] <High>: (Type D or H.)
Use this command to reduce the memory used by very large images.
When set to Draft, this command:
Toggles the image display quality:
  • Draft - lowers quality, displays faster.
  • High - raises quality, displays slower.
Left: image quality = high; right: image quality = draft.
-ImageAttach - attaches raster images to the drawing; displays prompts in the command bar.
ImageClip - clips images.
