PasteSpec
Pastes entities from the Clipboard through a dialog box (short for "paste special").
command bar:  pastespec
alias:  pa
menu bar:  Edit | Paste Special
: pastespec
Paste Special dialog when pasting drawing entities
Paste Special dialog when pasting data from an Excel spreadsheet
Choose a format, and then click OK.
Paste
Pastes the entities in the drawing.
If the entities are in BricsCAD format, you are prompted:
Select insertion point - specify the insertion point of the entities.
If the entities are in other formats, the entities are pasted in the upper left corner of the viewport.
Paste Link
Pastes the entities in the drawing, and creates a link to the originating application.
As
Chooses the format in which to paste the entities.
This list varies, depending on the content of the Clipboard.
Display as icon
Displays the pasted entities by their source icon.
CopyBase-  copies selected entities to the Clipboard with a base point.
CopyClip - copies selected entities to the Clipboard.
CopyHist - copies all text from the Text window to the Clipboard.
CutClip - cuts (moves) selected entities to the Clipboard.
PasteBlock - pasted entities from the Clipboard as a block at an insertion point.
PasteClip - pastes entities from the Clipboard into the current drawing.
PasteOrig - pastes entities from the Clipboard at the original coordinates.
Table - creates a table entity in the drawing through a dialog box.
