Table
Creates a table entity in the drawing through a dialog box.
command bar:  table
menu bar:  Draw | Table...
toolbar:  Draw |
: table
Choose options, and then click OK.
Table Style
Click the button, then select a table style.
Table Styles Explorer
Opens the Drawing Explorer - Table Styles dialog (see the TableStyle command)
Cell Styles
Choose the cell styles. The options are: Title, Header or Data.
The properties of the cell styles are defined in the table style.
First Row Cell Style
Click the button, then select a cell style for the first row.
Default: Title
Second Row Cell Style
Click the button, then select a cell style for the second row.
Default: Header
All Other Row Cell Styles
Click the button, then select a cell style for the other rows.
Default: Data
Table Options
Start From Empty Table
Creates a new empty table.
From Data
The cell content is read from a data file.
  1. Click the Browse button ().
    A File dialog displays.
  2. Do one of the following:
  3. Choose Delimiter Separated format (*.csv) from the File of type option button, then select a CSV file.
  4. Choose XML Spreadsheet format (*.xml) from the File of type option button, then select an Excel XML Spreadsheet 2003 (*.xml) file.
From Attribute Extraction
(not implemented yet)
Insertion Behavior
Specify Insertion Point
When the OK button is pressed you are prompted to specify an insertion point for the table. The top left corner of the table is attached to the cross hairs.
Specify Window
When the OK button is pressed, prompts you in the command bar:
Specify first corner
: Enter the position of the top left corner of the table.
Specify second corner
: Enter the position of the bottom right corner of the table.
Columns / Rows Settings
Specifies the number of columns and data rows and/or the column width and row height.
Columns
Enter the number of columns.
Column Width
Specify the column width.
Data Rows
Enter the number of data rows.
Row Height
Specify the row height.
OK
Inserts the table in the drawing (See Insertion Behavior).
Procedures
To create an empty table
To create a table from data
To create a table from an Excel spreadsheet
General procedure to create fields
-Table - creates a table entity in the drawing through the command bar.
Tablemod - modifies the properties of a selection of table cells.
Tabledit - edits the cell content.
TableExport - exports the content of a table entity in CSV file format.
TableStyle - creates and edits table styles through the Drawing Explorer - Table Styles dialog box.
Field - inserts a field in a multiline text, table cell or attribute.
