Polygon
Draws regular polygons, from 3 to 1024 sides.
command bar:  polygon
alias:  pol
menu bar:  Draw | Polygon
toolbar:  Draw | Polygon |
: polygon
Polygon: Multiple/Width of line/<Number of sides> <4>: (Specify the number of sides, or enter an option.)
Specify by: Edge/<Center of polygon>: (Pick the center point, or type E.)
Specify by: Vertex/<Midpoint of side>: (Pick a point, or type V.)
This command draws polygons by three methods:
This command draws regular polygons, where each side is the same length.
To draw irregular polygons, use the Rectang or PLine commands.
Number of sides
Specifies the number of sides; enter a number between 3 and 1024.
Multiple
Repeats the command to draw additional polygons.
Width of line
Specifies the width of the edge lines.
Polygons are made of polylines.
Center of polygon
Specifies the center point of the polygon.
Midpoint of side
Specifies the midpoint of one of the sides.
The midpoint of the side determines the size and angle of the polygon.
Edge
Specifies the length of an edge; prompts you:
First endpoint of edge - specify the edge's start point.
Second endpoint of edge - specify the edge's endpoint.
The length of the side determines the size and angle of the polygon.
Vertex
Specifies a vertex (corner of the polygon); prompts you:
Select vertex point - specify the vertex.
The location of the vertex determines the size and angle of the polygon.
Procedures
Drawing polygons
Grips Editing
Polygons can be edited directly through grips:
  1. Select the polygon. Notice that it has one grip at each vertex.
  2. Drag a grip to stretch the vertex. Note that the polygon is no longer regular.
Rectang - draws rectangles and squares.
PEdit - edits polygons.
