ProfileManager
Allows to set current, create, copy, delete, import and export user profiles through a dialog box.
command bar:  profilemanager
menu bar:  Tools | User Profile Manager
: profilemanager
Create
Creates a new fresh profile, using built-in default settings.
Profile name: Type a name for the new profile
Description: (optional) Type a description for the new profile.
Set Current
Select a profile in the list, then click the Set Current button to set a profile current.
The next time BricsCAD is started using this profile.
The current profile is marked in the list.
Copy
Creates a new profile as a copy of an existing profile.
Delete
Select a profile in the list, then click the Delete button to delete the profile.
Export
Select a profile in the list, then click the Export button to save the profile to a .
Specify the export folder and filename.
Exporting then importing a profile allows to migrate user preferences from one computer to another.
Import
Click the Import button, then select a *.arg file to import a saved profile.
Start
Starts another BricsCAD session using the selected profile.
Double click the profile in the list, or select the profile and click the Start button.
If the SingletonMode user preference is set to Yes it is not possible to have multiple BricsCAD sessions open simultaneously.
Use the Singleton command to set the SingletonMode user preference.
OK
Closes the User Profile Manager dialog box.
Procedures
Creating user profiles
Starting BricsCAD with a specific user profile
Restarting BricsCAD using a different user profile
Managing user profiles
To export a user profile
To import a user profile
To import a user profile from another user
Customize - customizes the user interface of BricsCAD: menus, toolbars, keyboard shortcuts, aliases, and shell commands.
